AFTERMARKET GAUGE CLUSTERS PICS
cawley
383 Bcuda
milton
If you have an aftermarket gauge cluster or you just added the gauges yourself lets see what you have. The gauge cluster in the 67 barracuda I am buying is missing & I like to see what options are out there. Other than stock.
EBay shows auto meter instrument cluster for the early cuda. It’s $900 though. Have a look. For some reason I couldn’t post a link, I probably just don’t know how.
For my Aus Chrysler Hardtop (Dart) I designed my own, then had it cut by laser out of 1/8” sheet, covered it in vinyl wrap (brushed aluminum finish) and ordered a set of custom Speedhut gauges.
Just in the process of wiring them up now!
Gauges in my Dart were junk . I decided to remake the hole thing. Gauges are Sun Pro and speedometer is GPS. Probably not the up scale your looking for . GPS is accurate and gauges are a huge improvement over OEM
I’ve been known to get there every once in a while, sounds like a great offer! Factory air car for you -nice!
Factory air nobs and parts, it doesn't blow cold air though :rofl:
Before next summer I'm going to try and have the compressor and hoses redone then maybe it will work again
there's THIS thread, probably more than you were thinking of doing.
here's mine, still in progress :rolleyes:. keeping the stock cluster and adding the others
No desire to f*up the existing dash configuration so I added a cheapo Sunpro set below the dash
Mine is a little more basic on early A, but eventually I ended up with only 1 stock gauge working so replaced the cluster. Added oil, water, volts where radio use to be instead of under dash. All Autometer gauges. I am thinking of redoing and making larger, change colour and incorporate other switches maybe.
I've looked around for gauge solutions for the narrow sweeper speedo used in the late 60's early 70's Darts and never found anything that would fit without a major dash reconstruction.
Then I stumbled upon the Itellitronix gauges and found their universal 6 gauge set and thought to myself "I can make that work", so I bought a set and went to work and here is the result of what I able to do.
The rally instrument panel isn't often replaced with something aftermarket. You would probably find more examples of it being used to replace a standard panel. Good luck
Not the best picture but all I have at the moment. I did this about 20 years ago but the picture is from this last Saturday.
Nice. Did you build that?
No I had a company when I was down in California build it, can post up their info if people want to contact them, they still have the bend angle for it. And they can make any size pods just need to know the gauges your going to use.
