BLOW-DART
Ive been meddling in many different threads with questions about heads, cam specs, etc...
Id like anyone's input on the combination I'm putting together because I know there's a lot of knowledge on this forum!
To start with the motor. this is the engine i have in the garage that is not yet in the car but will be in a couple weeks.
its a 360 block out of a 73 or 74 roadrunner, rebuilt with factory crank, new rods and keith black hyper pistons, compression was requested to be 9.75:1 when i had it built at the machine shop but i dont have any numbers to prove if its exactly that or not.
new double roller timing set, new water pump.
J heads with 2.02/1.6 valvles open chamber, valve job, new seats, springs, retainers etc, just a basic head rebuilt, exhaust ports gasket matched with no other porting or polishing. original rocker assembly with new pushrods and lifters(hydraulic)
i think the cam is a purple shaft(this motor has been built for a few years so im a little foggy on some of the details. the two specs on the cam i remember is 284 duration and .484 lift.
edlebrock airgap intake with a demon 700 mechanical secondaries and electric choke.
this will be placed in a 1964 barracuda, with custom headers, a 904 pushbutton with a tci shift kit, 8 3/4 rear with 3.55 sure grip, and tires 245/60/15 on steel wheels.
the rest of the car is fairly stock at the point with the exception of 4 wheel disc brakes.
motor has been run in a A100 van a few years ago for about 1000 miles if that and ran strong but was running with a high end accel dual points system. i will be running it HEI electronic.
Now I would like to hear some feedback on the build and set up with any reccomendations to the motor set up, drive train set up (torque converter selectiong) etc.
Use for this car is not a daily driver, its just a toy for my wife and I. we will be taking it to infineon a couple times for some amateur bracket racing and taking it shows and cruises. let me know what you all think...
