air cleaner
vallianted
fenelon falls canada
putting a small block in our 65 Valliant with a stock 360 intake and a holley 600 carb.would like to know which air cleaner will fit.
If you have a stock 65 Slant 6 air cleaner you can buy a 4bbl aftermarket cheap air cleaner,use the filter(2'') and use the lid
from the Slant.You can use 6-10'' chrome aftermarket air cleaner for the base. I usually do 9''.
I have done this many,many times.On the Hemi I needed a bit more hood clearance and notched the lid for the fuel line.
All cars ran AFB's. You may ahve to do experimenting with a Holley.I doubt there will be a difference.My 2 cents..
I'm not familiar with 65 valiants . Do they have to use a small diameter air cleaner?
Ya I still have the 6 in the car with the super six air cleaner on it.I really like the look.
Yes earlier slants had smaller diameter and did not have the CAP nipple that went to the valve cover breather.
I have seen both, this photo was from my stock 1964 Dart
I can image that little air cleaner choking 30+ hp out of that Hemi.
Didn't matter.Not a racer. Just street driven. I removed the cross ram and toned it down to make it a nice cruiser.
