[SOLD] Air Gap Intake small block!
slowburn
Active Member
Wisconsin
Aluminum Dual Plane Air Gap Style Intake, 340-360, Dual Bolt Pattern,will fit 1967-2003 including new 318/5.2 L,and 360/5.9L Magnum Heads.
Also earlier 273-318 w/ 4 BBL Heads. Has NO Heat cross-over ,Heated Choke, Or EGR.Good for 1500-6500 RPM power.Runners can be drilled for Nitrous.
is similar to Edelbrock 7576 rpm air gap intake
asking 100 you pay shipping
Just so there isn't any confusion, this is a Chinese knock off of an Edelbrock Rpm Air-gap made by Pro Comp or Professional Products. I have one on my motor and so far its been great! Nice price too. Good luck.
Better casting technique, much closer tolerances in the port area, slightly smaller plenum volume for better low RPM throttle response, would run one in a heartbeat over the Edelbrock, Grind off the name if it bothers you. Takes a polish well too. MHO.
Your Ad was deleted by staff. Please review the "for sale forum" rules before posting again
will this line up correct with a 360 la engine with 71 j heads if it will write me
i will take it today i"m in sun prairie wisc next to madison if your close enough i will come and pick it up or call me at 1 608 837 4427 Jon
