dartsport73
Recently I had to do some work on steering column. (Signal switch) Now when I shift to any gear out of park it starts rolling like its in neutral.
I will say, I added a new instrument cluster while steering wheel was off and once I had finished, everything was fine... until I realized that I didn't plug anything in. So, I re-undid the bracket holding the column up and slid the instrument cluster out of its area. Once that was done I refastened the bracket underneath column. Once done the second time, that's when this new problem started.
Some info
1. Manual steering
2. Non collapsible column
3. Center horn button type steering wheel.
4. MOPAR PWNZ
All help is appreciated.
Some info
1. Manual steering
4. MOPAR PWNZ
