whiteeagle
The other thing is, if you are putting 340/360 heads on a 318, the larger chambers will drop the compression.
I don't think the first set of heads mentioned were actually 72 model heads even if that's what the year vehicle they were in. 72 didn't have the smog tubes. Casting numbers would clarify what heads they are.
In my experience this can be completely compensated for by installing 2.02 intake valves in the 340/360 head.
