I love that video!
Perfect! Just wanted to make sure you had received it, since I had given you the incorrect email address when we spoke.
Ponder away!
I make weld-on upper control arm mounts that can be used to fix or alter stuff, or use the system in a street rod, but I'm not making that change in my own car.
I was also wanting to run my car fairly low, ive decided to go with the RMS Alterkation. Ive talked to Bill Reily (RMS) about the options and what im doing is using the wilwood 2" drop spindles, Bill said this would be ok for a show car, but not a street car as the RMS k member would be far to low to the ground, since i want to drive my car on the street i will cut the cross bar on the K member and raise it 2", this will also do away with the need for the spacers bill uses on the end of his steering arms, i will need to raise the engine in the car (i have a Gen3 Hemi), not sure exatcly how much i will need to raise the motor yet, will likely depend on which sump i go for. Hopefully will find out in the next couple of months all going well.
how low do you want the car? call and talk to bill directly before you do any more re-engineering of it in your head. he will be more help then anyone here. and you do know that the alter-k doesn't use a mopar style spindle right? your not going to be able to use a magnumforce spindle with it.
the alter-k was designed for handling in the first place. the drag race thing was just an added bonus with it.
Just what Mopar spindle does it use?
...be aware beforehand what all this will entail - if you raise the rack 2", you'll also have to raise the engine 2" to keep it off the floor, which you'll also have to raise the trans 2", the exhaust 2", the rear 2".........actually just raising the whole tunnel will take care of most of it, but the exhaust will be tricky. Off the shelf headers are out of the question.....header collectors do not like bridge abutments, I'm sorry to report LOL
On the RHD, you're screwed for headers - all of them on the market take up all the space on the right side of the engine in an a-body. You're better off to just avoid the disappointment of modifying $800 headers, and just do custom ones down there once you have all the steering connected.
