anyone have any issues keeping your alternator belt from coming off ? 410 stroker, stock style Powermaster alternator, stock pulleys. Ive checked and rechecked the pully alignment with a straight edge, replaced the power master pully with a deeper stock style with no help. the belt is a new Year one repro that im replacing with a different brand or style and see if that helps, but i cant see any problems that would cause this. I even pulled the field wire to see if there was a charging issue causing the problem
