drive around for a couple hours in the middle of the day and slap your hand on it. should be plenty hot. i'm supprised it didn't fry the coil
Ya, but most of that heat is generated because it is actually DOING WORK, IE bearing friction, heat transferred to the rotor by belt friction, and heat generated by the stator windings and the diodes.
In this case, all he has going on is a couple of amps of rotor (field) current
The stator/ diodes should be "same as" any other time the car is shut down.
