bootsnbolts
1962 dodge lancer, /6 225
1) ALL new electrical system (pickup coil, dist, elect. ig., volt reg, etc.)
2) recent complete valve head rebuild
3) new alternator (third)
4) new battery (second)
5) wiring trouble shot a million times
here's the issue as i see it:
shortly after a friend put in the rebuilt valve head, she started throwing a lot more oil from the front seal, which got up on the alt and belt. i figured the high-pitched whine i started hearing was due to the belt slipping from the oil OR having gotten into the alt. i got TWO alt tests, first one came back no charge so i got a replacement on warranty. threw the new alt in, still hearing whine, still having to charge battery overnight to keep running. i have a kid who needs rides to and from school, so that was the best immediate plan.
yesterday, i'm driving along and i get no acceleration, and dying out. pull over, pop the hood, see fuel squirting into carb as it should when i manually pump the acc., slosh test says there's gas, so just to be safe i run up and get more gas, as she's really acting like she's running out. that is to say, my bf ran up to get gas, while i jimmied around making sure the wiring was all tight. put gas in, drives fine for about 10 blocks (downhill), then starts flailing again.
another symptom: since the valve rebuild, i had her distributor timing adjusted, was fine for a week or so then pinging starts getting worse and worse as charge issues get worse.
so we pull her over and pop the hood again. start d*cking around with the alternator, i notice the belt seems loose, we go to tighten it up and the bolt receptor (don't know what it's called) where the arm bolt is supposed to hold the alt in place AT the alt is stripped. can't just replace bolt, as the prob is internal on the alt. a bit more sleuthing, and we discover that the arm itself where it bolts to the head is not tight. the bf had noticed this before when we exchanged the first alt, tightened it up, yet again, here it is, loose as *&%^, giving me too much belt play.
my first thought is that the friend who replaced the valve head after the rebuild may not have remembered to tighten that arm bolt to the head properly, i did NOT have any issues whatsoever with my charge before that. so here's my question: if the alt is not being held down properly, causing the alt to jump/bounce, would that explain the bolt stripping, causing the belt to slip due to being loose? would this cause my car to lag, stall, and not accelerate properly?
why the increased pinging? i paid a lot of freaking money to get my valves done and i sure was loving that compression.
also, if that bolt to the head that holds on the alt bracket is stripped, how screwed am i?
i've ordered another alt on warranty, should at shop around 11, i'm planning to just pull the alt that's in her, walk it over to the store, get the new alt, tighten everything up real good and hope things are resolved. once i get her home i can start worrying about getting her rear brake cylinder fixed.
