red cuda
So, I got my new alt brackets in, but I cant figure out how they mount. its like they need a ton of spacers to bring it out to line up the belts. I would like to see some pictures, to get an idea. Thanks.
it looks like I may need a deeper water pump pulley. im gonna try everything tomorrow.
Hello, well I got my alternator brackets on with new alternator, now my belts are a bit off. the pump seems to be a little far forward. did mopar make different lengths water pumps. I have a single groove pulley. do I need the double groove, or a deeper single groove? not sure what to do here.
i just have the alternator. i got it set up, but it still doesn't line up. the alt is still too far back. my crank pulley is 3 groove, and my water pump pulley is 1 groove. i had to start from scratch. i had the partial set up, which was the crank, and water pump pulley, and they were from a engine with AC. whitepunkonnitro says i need a matching set from a non AC engine.
@krazykudaAccording to the instruction sheets for the Bouchillon Performance kit # BPE 5251:
The long spacer is 2.105" long
The short spacer is 1.210" long
Some hardware stores carry 3/8" spacers. I would think that you would be able to go to a hardware store (Like a local Ace) and buy 3/8" spacers in 2" and 1.25" and get them to work. The long bolt for the alternator that the spacers go on is also 3/8" x 16 x 5" length.
Some of the hardware stores also carry the "generic" 3/8" spacers in chrome plated, but some keep them in the back and you have to ask.
