jimmyray
- Joined
- Jul 17, 2007
- Messages
- 951
- Reaction score
- 31
I have replaced my Alternator and Voltage regulator (AC Delco, the Best one Advance Auto has)
When the car is running, the Ammeter is steady sometimes, and other time is pulses, or blinks, on and off. This causes the interior light to flicker at the same rate.
I ran a wire direct from the alternator to the battery, and replaced the hotwire to the Voltage Regulator with a new one direct from the relay I am using to power the ignition.
I have cleaned the plug, and have 2 screws with star washer grounding the voltage regulator.
Thoughts?
Thoughts?
