UPS delivered the Universal 73 ohm fuel sender today.
I again welded a few scrap 1/4" aluminum pieces together to make a mounting ring for the gauge.
Once welded up, I chucked it up in the lathe and turned the ring.
I then laid out, drilled, and tapped 5 10x32 holes for the gauge and 5 6x32 holes to mount the ring to the top of the tank.
I am going to recess the gauge about 1" - 1 1/2" below the top of the tank for wire clearance.
I also got the mounting plate for the recess made up.
I did a little welding on the tank before calling it a day.
Herb
Herb
