AM I RUNNING GOOD?
midnight
Member
Sheffield AL
My duster was a 360 with a pair of j heads on top of it. A edelbrock torker intake and 780 holley.It is wired up with a complete msd ignition .A 4000 tci converter a 509 purple shaft cams and it is bore 030 over channels the power to a 456 geared 8 3/4 MY BEST RUN IS 60 FT. 1.549
330 FT. 4.702
594 FT. 6.930
1/8 ET. 7.412
1/8 MPH. 93.36 P.S IT WAS 28 X 10.5 MICKEY THOMPSON ON IT
SO U COULD SAY ITS GEAR 430
well I guess I'll tell you about mine. its a 75 duster. 451 ross 10.3. 906 heads, comp extreme 507/510 hyd. M1 750 holley. car weighs 2930 empty, 9.5 4000 stall. 410 gears. 28/10slicks.
best so far. 60ft 1.49 1/8 6.93 99.07 1/4 10.91 120.68 not bad for a hyd. cam. and they say it can't be done.
i hope to have one soon,i need a scanner, got a question. how do you put your combo in the registry
The 60 ft's are great. I agree about the manifold. I would go with the air gap. I ran one on my old 340 vs an M1 and it out performed the M1 hands down. I ran 11.80's with that set up in a 3420 car.
