Slant Six Bumblebee
What is the ideal resistance for ammeter my old ammeter had 9 ohms and a spare one i have is 1 ohm is that still to much?
So what are you basing this calculation on?It’s the stock ammeter for my 72 slant six dart. I calculated the meters ohms into the .9
My multi meter with the ohms of the leads subtractedSo what are you basing this calculation on?
Something is not right. Whether its the ammeter, or the multimeter (Digital or analog) I don't know.My multi meter with the ohms of the leads subtracted
ok ill give this a try i got a wiring diagram and was tracing the voltage drop everywhere and the only places that there were any were the link and the ammeter. Is there a better option than the fuseable link?The thing is you CAN NOT accurately measure low values of resistance with a multimeter. This varies with the quality of the meter, but below two or one ohms, you are getting flakey, and something like Horrid Freight/ other Chinese import, maybe higher than that
The only real thing you need to be concerned about is total voltage drop when charging hard, AKA with 20, 30, 40 A going through the circuit, THE ENTIRE CIRCUIT, which includes the fuse link----the connection at the start relay "big stud"---the wire end terminals----the bulkhead connector terminals---the wire terminals at the ammeter---of course the ammeter itself, and so on
This figure varies with opinion, but "Let's say" you have a 50A alternator operating at that output, you have a load on the battery to simulate heavy load, if you have anything less than 2V between alternator output stud and the battery POS stud, I'd say "call er good."
The bit issue with the ammeter is that the studs are not soldered/ brazed/ welded to the shunt/ guts. These connections can get hot with extreme current especially with something "got loose" and a little corrosion, etc. If you want to improve this, take it apart, clean it up and using proper flux, solder the studs to the shunt with silver based solder
no load just my battery plugged in. i bolted the two ammeter terminals together for testing. I measured at the ammeter terminals and the alternator with the car off and all the voltage drop comes from the link with no ammeter in the circuit.THat's a tough question. The fuse link is darn poor protection, and yes!! LOL!!1 I have a story about that. But a breaker might be worse. A breaker small enough to protect the wire might nuisance trip under high charging loads
Just where are you measuring the drop, under what kind of conditions (electrical load/ charging current) and how much is it showing?
