Mattax
Just the facts, ma'am
By running 10g wire from alt output to battery side of starter relay it then carries most of the load to charge battery instead of sending all through bulkhead connector were thing tend to melt down if Iam reading correctly.There saying to use a fuse link in line of 10 g wire
The battery recharging is only a high load if the battery has been run down.
Yup.There saying to use a fuse link in line of 10 g wire
Fusible link is mostly to protect against battery grounding.
Any additional protection it provides is a matter of luck.
In my opinion, the best way to reduce the load on the bulkhead connectors is to parallel the feed wires. At least the alternator feed. But doing the battery feed wouldn't hurt, its just a little more work because it should be spliced in at the fusible link.
Current flow will look something like this while the battery is recharging.
