AN Power Steering lines
siuauto
Joliet Illinois
Is anyone running braided stainless power steering lines. I have some line and I was thinking about using it for my lines. I am looking for some pics and what size I should use. I have -6 and it looks like it should be ok. Does anyone know if the push lock will handle the high pressure? Thanks in advance.
Stainless is just fine, -6 for the pressure, -8 for the return. Push lock wont last when you have the wheel turned all the way in either direction, the pressure is tooooooo high.
Whenever I do a hydroboost, I end up replacing most of it with teflon lined braided steel line designed for PS. Aeroquip makes a fitting for the PS gear hipressure side.
great, I think I am going to tackle this. I am still looking for some pictures. My engie is out and I was hopping to see what angle fitting I would need. I hate the way my factory one look.
