And so it begins. 69 Dart GT resto
Been following for a long time. Great thread. Don't remember if you already did or not, but figured worth mentioning...since you have k-frame out consider welding factory stitch welds solid and possibly adding gussets to further strengthening it?
How do you weld in gussets? I'm not familiar with this. Any pics? I will weld the factory stitch welds while it's out.
A gusset = triangle piece of flat metal placed where support (from a horizontal to vertical) is/if needed. As far as lower arm stiffening, as mentioned above flat stock welded to bottom don't cover torsion bar adjustment nuts. Look at picture online and copy.
I got the k-frame back from blasting. It's a mess. The previous owner couldn't weld to save his life. I have a lot of cleaning up to do.
While Tin Cup is doing the rear wheel wells, I've been cleaning the engine bay. After about a good 10 hours on it, I'm almost done. I had to order more abrasive wheels.
Over 12 hours cleaning up the engine bay. Almost done.
Tin Cup finished the mini tubs. We'll get some primer on and seam sealer. He has to order a good spray-on undercoating for durability. I'll be cleaning up underneath before installing the axle and fuel tank along with all the hardware.
We've been taking a break on the Dart. Summertime equals car shows and vacations. Still got some things done. Engine bay is finally painted.
I've welded up the K-frame and LCAs. All suspension parts are cleaned and painted. New urethane boots to go on. Also repaired, blasted and painted oil pan, intake, water pump housing and other parts. I'll get pics later.
Underneath the trunk is sprayed with bedliner and we used the tintable bedliner for the inside of the trunk. I already started assembling the rear suspension and the 8 3/4 is on the floor read to be put in. I'm gathering all the fuel tank stuff to get that mounted also.
