Babyblue66
Cool dude
I put this together last winter for a friend. It was an assembled engine he got with a car. I took it apart, had the assembly balanced and the hone lightly redone. It has speed pro pistons, 8.8 to 1 with a felpro gasket, 2.14, 1.81 valves, I did a little porting in the bowls, Comp Xe268 cam which is 224 230 @050 on a 110. Windage tray, stock intake and a 750 quick fuel carb. It made 380hp and 421 ft lbs. Very very close to my 383 I just dynoed. Doesn't take much to get these Mopar to 1 hp per cu inch.
