JGC403
Disc Brake Swap, 11 3/4" rotors and LBP wheels.
I know it’s been covered before on here I just want to make sure that all of what I found is correct. I have been trying to figure out what all is needed to convert my 1968 Barracuda to disc brakes with the larger bolt pattern. From what I have read I need the following parts from a 1973-1976 A body:
-Upper and lower control arms
-Spindles
-Calipers, larger piston bore from 1976 A-body or 1976-1980 F-body
-Rotors 11 3/4" from 1976-78 B-body or 1979-81 R-body
-Caliper adapter bracket from 1976-78 B-body or 1979-81 R-body
-Master cylinder
-Valving
I have read that you might loose some of your turning radius if you use the stock drum brake lower control arms. So is it easier to use the 1973-76 A-body lower control arms? I have also read that stock sway bar will interfere with the calipers.
Am I missing anything? Just want to make sure I have the right parts list before I go looking around the Junk Yards. Thanks.
-Spindles
-Master cylinder
-Valving
