another ''whats it worth'' thread/question
famous bob
mopar misfit
okla
1968 fastback , resto mod , everything is new rebuilt or replaced between the bumpers , even the front one is new fiberglass. Rewired , 440/505'' , race balanced by hughs engines/cant feel it running on the motor plate , block and mains were cryo treated before machine work , new 28x19 alum. griffin radiator , alum water pump housing/w milodon pump/short clutch 17'' fan , booster fan in front , all the typical machine work, (only took .003 to square deck ) , 10.3 comp., 727, dana 60/373 gears, detroit locker , 295 65 15 sticky treaded hoosiers in the rear, full caltrac system , stock massaged fenderwells/front stretched before new paint and body work , interior is a black business coupe set up , 6 point roll bar, ''swing out in trunk for drivers side'' , stock buckets with custom upholsery, new black carpet , turbo action cheater shifter in stock console / moved back about 4'' , fast 2.0 fuel inj./1200 cfm throttle body , , return system , works well , brand new battery and starter, 2'' tti headers , subframes tied/welded solid in floor , weld prostars all around , new front 205 70 15 tires , , solid street roller w/ morell lifters , cnc victor type heads , (flowed 354@.600 lift) , fiberglass 6 pack hood/pin on , j bars tied to firewall and to 2 shock tower locations and front frame rails ,, are removeable w/o cutting. Custom driveshaft was built for 700ish h.p. back in the build , currently has a mag. force tubular dragracing front end in it , fine on decent roads, have the stock k frame ready to go back in/ clearanced for the 9 qt single line milodon pan , approx 1400 miles on the car, only 2 runs at the strip 3 yrs ago, had virtually no front end lift at the time , rings werent seated then and too small 295 drag radials on it , have since installed new front coil overs w/ the correct 250lbs springs . Car went 11.90`s spinning , gaurantee its faster now.
Probly for getting some stuff too---------
I may have a slim shot at a hemi car , ''may'' , once u`ve owned a hemi , it stays w/ u for life
Just testing the waters , what`s it worth ? ----------Bob
Oddly enough I think the high HP and race oriented equipment may reduce the number of buyers. You may be better off converting it to more of a hot driver and sell the hard core stuff seperately .
The question is more about what someone will pay. It’s not worth the sum of the parts. I’d say because it’s more go than show somewhere in the $20-25k area? More if you find “the ***” for your seat.
Not entirely true, the guy that painted it for me tried to talk me into putting it in car shows , it would need the door handles replaced , along with the tail light housings , and of course a little detailing ------
forgot, 4 wheel disc brakes , all new brake lines too.
IT IS between a drag car and a driver ,the reason for getting ready to re do the orig. front end . I got old while building it , the reason for thinking about changing stuff again , still a kick a$$ street car tho.
Sure is neat wasting corvettes and mustangs on the 4 lane .
I'll see your $20-25 and raise you to $30 g's. Second gen Barracudas are hot. On the street or on the track.
So you’re going to pay that for it? No. You just think somebody else will. I’m a skeptic. Im not saying it’s not nice. It’s a cool ride and looks well done. But the market is not “all that” for customized A Bodies. If it was a Hemi clone done to look original I’d agree. It’s a hot rod, and personalized. So seller needs to find the right *** for the seat.
you have no idea of how much I`ve thot of a street hemi in it -----------------a little short on the hemi thing !
Always remember - you only need one buyer... If you aren't in a hurry to sell you might do really well at the high end of the scale.
