Any bolt in 22" aluminum radiators?
carcrazyguy
Amarillo, TX
Anyone know of someone that makes/sells a bolt in 22" aluminum radiator that has electric fans already mounted?
Sometimes. Depends on the year, your exact engine and accessories. You need the upper and lower tubes in the correct place and size, which depends on your water pump and where your AC compressor is. 65-66 cars use 22" radiators but are narrower between the frame rails than 67+. Anyway, many posts on here w/ photos.
Not all radiators fit all applications so the first important thing is what car you are working on? Second thing is what water pump and engine you are using so the hoses would be in the correct location.
Going in a 70 Duster that will be using a 360 block and MSD Atomic EFI. Trying to find something that will work with that for the electric fan controls.
Champion has them in 2,3, and 4 core with 10" fans, or you can get the bare radiator like I did and use a Spal 2052 dual 11" fans that need very little modification to fit.
Smiths is building mine as per spec that we discussed! Upper hope pass side lower hose driver side . Two 1.25"rows with no tranny cooler!
Pauly on those fans. What cfm are they and where did you get them?
http://www.the-fan-man.com/shop/siz...th=33&osCsid=7f0830c55c4ab009fb6b37d25cfd8638
I liked this fan because it was one of very few that fit between the front snout of the water pump and the rad, and of course fit the 22" rad. It takes up less space (depth) in the area between the fan motors
I have the drivers side fan running through a controller and the passenger side fan on a switch on the dash for when I'm stuck in traffic, it works quite well this way. -pauly
