any way to remove J-B weld?
From my luck with JB weld I found best way of removing is just to wait a few weeks, it will come off by itself. Never got it to work on anything I tried. MT
I was thinking the same thing......... Just wait it will fall off soon
Like TB, I have worked on bikes for many years, as a dealer tec, and I have found that the cases can most times be welded "in situ", if you can find the guy to do it.The exception is where a crack is intersected by a glue/gasket joint or as TB mentioned, if the crack gets into a precision bore or journal.
It takes a bit of prep work,tho. Sometimes the bike/quad has to be flipped on its head or suspended in a specific way to be able to keep the joint clear of contaminating oil. Still cheaper than a teardown, and if my welding tec says he can do it, I trust him.
well,ive had this bike for over a year and it hasn't leaked a drop through there
it kinda got put on the back burner but I should see if I cant play with it some
