Die grinder and bits for porting- it's been a while
Cruisingram
Pahoa, Hawaii
Tips, hints or advice on buying a new die grinder to clean up and port match my heads/Manifolds, plus working on the exhaust manifold as well. 40 years ago I bought a giant electric die grinder and ported heads on the daily. Now it's been probably, at least 20 years? Since I did my last job, don't have that die grinder anymore! Anyone have one they really like? I prefer Electric to Air, simply because I don't want to have to worry if I got enough volume out of a compressor to make it happen. Best place to buy bits? Any advice here will be appreciated.
I have an old Craftsman model that I bought...40(?) years ago. Like it and it worked good last time it was out chewing up metal. If not new, garage/estate sales? sorry, not much help.
Not much help im sure (sorry) but air power is much better for something like that
I recently bought a Hercules eletric from harbor freight. I haven't used it much, but it's well balanced and light. I believe it's variable speed.
Problem with air is you'll run out of it long before you run out of electricity
Just looked at it and it's not variable speed.
Just my observation, which you probably know. With what little I have done, using a lubricant makes using the tool smoother with less grabbing and jumping. I used wd-40 which worked for me. It also keeps the chips from flying so bad.
Yote
Yote
I have always used vaseline to catch the chips too, really slather it in the intake and exhaust areas, catches most of the metal.
Radar and Woody used Bosch and Makita. Electrics are more consistant rpm wise than air grinders. These are my 273 heads
I’d like to see what people are using nowadays. There used to be a guy in town here who used a big Milwaukee die grinder with abrasive rolls to match and clean up ports. When I was still working on motorcycles I ported dozens and dozens of two-stroke cylinders, and a few four-strokes. I used a CC Specialties rig that was basically a Foredom unit set up for porting. It had a foot pedal and a hanger hook that made it very easy to use. The tool holder was set up with a 1/4” collet that worked will with the various carbide tools that I used, both long and short shank. It was easy on your hand, too. I also had a 1/8” collet adapter for small burrs when I needed them. Beeswax was my favorite lubricant. It would load up my burrs sometimes but that was easily taken care of of with a brass brush. That setup helped pay my way through college and buy my first house. I still have it. The drive cable broke some years ago and CC Specialties was out of business when I tried to get a replacement. The motor never failed and I don’t think I ever replaced the brushes even though it came with a spare set. If anyone knows where I could get a drive cable I’d like to know. It looks just like a speedometer cable. I’d fix it up just for old time’s sake. I also used some pneumatic die grinders like Astro and Florida Pneumatic. They lasted pretty well if you pre-oiled them, but I did wear out the bearings in a few of them. Long shank bits seemed to make them more prone to chattering when worn.
