Anybody use Wilwoods w/a power booster ??
MoparVT
Barre VT
I am looking into doing a wilwood swap on my 72 swinger. I found a kit (on e-bay)that uses the stock 9" spindles. I asked the seller if they worked w/a power brake booster and they said it did. I just want to be sure.
Thanks
My goal is to put power discs w/4piston calipers w/drilled/slotted rotors on all 4 wheels. I just want to know if this set-up is going to work..... (wilwoods designed to work w/booster)
Any other opinions,ideas,or advice ,is always welcome....
Thanks
I did a swap to four wheel disc on my 1967 Barracuda. I switched to the large bolt pattern and I used Aerospace Engineering kit. I have power brakes but I had to change the master cylinder because I also used four piston calipers all around and they need a larger diameter master cylinder. I don't know much about the wilwood but I understand they will work.
cuda67
We have a set that uses all PBR factory calipers, and includes disc brake spindles in the kit. 13" front, 11.75 rear drilled/slotted rotors.
Yes,I've looked. The wilwood kit uses 4 piston calipers ,drilled/slotted rotors,braided SSlines,etc.etc. for 1/2 the price. (uses MY spindle).
Dont get me wrong,the XV stuff looks top notch....but bang for the buck is where I am at....
SO....does anyone know what prop. valve or metering block I need to use???
Thanks
Are you doing the total conversion all at once or are you going to use your drums on the rear?
