Anyone Deal in ATI Super Dampers or Advice on Were to Buy One
Glad you got setup Tom. Not to hijack your thread but can anyone tell me what the deal is with ATI dampers and Sm Blocks? I hear you have to grind the timing marks off of the timing cover to make them work.
TIA,
Bill
Not the best picture but I didn’t grind mine off
You're not hyjacking Bill, but you might want to post a thread in the small block section since more guys will see it than buried in this thread.
Tom
That was intentional.... I always try and hide my newbie posts as to not expose myself. :lol:
TIA,
Bill
What you said is true. I was actually making shims to go in front of oil slinger but that did not work. That's why I shelved my ATI for another manufacturer. You can possibly use the 273 timing cover.
Here's the footnote for the sm blocks....
2. Hubs are dimensioned to clear the stock cast-in timing tab on MOST applications. Due to changes by the manufacturer overtime, the tab MAY need to be ground and re-welded. The damper face for pulley mounting will be forward of the OEM location by .150” for 2-ring internal balance, .450” for 3-ring int. balance, .750” for 3-ring ext. balance. Hubs may be shortened by the listed amount for internal balance & by .600” (.150” fwd of OEM) on ext. balance if tab is cleared. 2-ring int. balance can be installed in OEM location with minor clearancing of timing tab & retain OE timing mark.
