65Val
Average Length Member
Anyone have a factory console tach in their '67-'69 Dart? I'd like a pic of where your wiring goes, especially through the firewall.
Yes, I know. I have the harness...just need to know where to drill the hole for it correctly.The cars that came with console tachs had it's own wiring harness
That would be great! I'll PM him Thanks C!@dart4forte has that tach. Maybe he can help you?
OK...I got another 2 pics from another member, with the hole in a different spot....
Next to the black circle, Steve?...I believe its a wiring connector...2 part tach harness.Is that a condenser connected to tach wire?
I'll bet the big block tach-to-firewall harness is the same small block one....they just use a longer wire from that connector to the further-away coil on a big block.Next to the black circle, Steve?...I believe its a wiring connector...2 part tach harness.
I think you might find your B'Cuda has the tach wire going through the bulkhead connector, as B'Cuda's had the tach in the dash, not the console. I stand to be corrected when you get your car back!Yep good call! Curious to get the cuda home. I'm sure mine is in same spot with a grommet, but no connector.
