Anyone running 11/16" Tie Rod Ends?
Rocket
CT
Are any of you running the 11/16" tie rod ends? If yes what did you use for the adjusting sleeve? I know there are solid sleeves available but I don't think I need that much beef there. I was wondering if there are strong sleeves available from moog or others that would improve the strength and resist flex vs. 9/16" tie rods and stock sleeves.
Thanks
Thanks
I have run them for years. Moog part number E355S (both sides same)
Typical application is 72 Plymouth Fury (C-body)
