DartThis74
I installed A b-body 8-3/4 rear in my '74 dart sport. If anyone is running American racing torque thrust II, what are you using as the offset to keep the wheel away from the wheel lip?
air shocks
air shocks
how much wider is your b rear than the a was, b rears came in 2 different widths.
.....I'd say with a 235 on a 15x8 you'd want a minimum of 5" of backspace, 5.25" would be better. You can go with more backspace than that too (probably up to about 6.25" of backspace), but the TTII's don't come with more than 5.25" of backspace in a 15x8. If it's a '65-67 than a 15x8 with a 5" backspace should be a piece of cake, and anything up to about 6" of backspace on a 15x8 would be fine.
I have a '68-70 B rear in my Duster. I run 18x10's with a 7" backspace and 295/35/18's, although I also added a 1/2" spring offset kit when I converted mine (perches at 42"c-c) and trimmed the outer quarter lip a little to squeeze the 295's into the stock wheelhouse.
In 15 it might be hard but once you move up from there most modern rwd vehicles are designed with higher offset numbers and there are plenty of aftermarket wheels companies that make wheels for them.
My wheels are from a new edge mustang.
Yeah, I can see Mustang wheels working on the back, if they want 17" or bigger wheels. But you can't run those large positive offset wheels on the front. So what goes on the front?
Wheels with that much backspacing are going to be custom one-offs (usually). Many wheels cannot be custom ordered, and many styles can't even be made with those dimensions. Trying to find a 15x8 with 5 3/8" backspacing for mine right now, and cannot find anything. What wheel companies are you getting this type of wheel from? And then what do you put on the front that matches?
Wheels with that much offset are common in 17"+ diameters. In fact, wheels with that much offset are the norm with 17"+ wheels.
My rims are off the shelf, nothing custom about them. Enkei RPF1's. The rears are 18x10 with a +38 offset (7" backspace). I run 295/35/18 tires on them.
As for the front, once you go up to a 17" rim you can run as much as 5.7" of backspace on an 8" wide rim before you start to run into outer tie rod end clearance issues. I've seen a 17x9 with 6" of backspace on the front, but that would be specific to the design of the rim, most of the Mustang Bullit rims start to hit at 5.7".
If you go to 18" rims in the front, you can run even more. 18" rims can fit the outer tie rod inside the diameter of the rim, so, your only limit is the frame. My front rims are also Enkei RPF1's, 18x9" with a 35mm offset. That's a 6.4" backspace. Now, that isn't the whole story, I also have Dr. Diff 13" rotors which widen the track with 3/16", and I run a 3mm spacer. So, my effective offset is 27mm. But I also run a 275/35/18 up front. With a narrower tire you wouldn't need the spacer, and that amount of offset would be fine.
Honestly, the 65-67 B-rear is perfect for the Dusters/Demons/Dart Sports if you're going to run 17+ rims. It makes the backspace needed the same front and back, so you can rotate tires. The 68-70 B rear is a little wider, which is why my offsets are at 38mm in the back and 27mm in the front. The 65-67 B rear would even them up the offsets needed.
Why isn't the rear tire centered in the opening?
