72BBSwinger
That is freakin awesome! I need to do a pull on my fronts, would love 295's on the front. 18x10's with 45mm offset im thinking.
Tom, you still running 11.75 Cordoba rotors? How fame rail clearance at full lock? Any spacer in front with that wheel? Also are those rears 305/30/19 on 19x11's? Was kicking around do those on all 4 but im thinking the diameter might be deal breaking on the front.
I think you would love Dr. Diffs 4 piston 13" kit, otherwise talk to Ron Sutton about some of what he carries.
Still running 10.75 stock 73+ rotors! Need to upgrade those ASAP. Keep hoping someone will make a 13" 6-piston kit for my 73+ spindles. I do run 1/2 - 3/4 inch of spacer, no problems with frame rail clearance, doesn't rub, but haven't measured it either. My rears are 19x10.5 with a +25 offset....
bringing this thread back. it's not too old.to anyone who's running either of the DrDiff 13" fronts. with what K-member and sway bar? still loving them? any problems?
thanks
brembo-style
cobra-style
thanks MuuMuu, I saw your thread on the wheel buy and thought they looked good on your car. I was wondering if 18's were going to be a requirement for the big brakes, hoping to run 17x9's. did the 17's just rub? may be possible to clearance the caliper a bit if it's close. are you still on a pre 73' K-member?First off, I'm running the Hotchkis TVS. The Hotchkis UCA's have a big curve in them (some other aftermarket tubular UCA's have them too) that cause interference way before full-lock, so the calipers have to be front mounted. Looking at it, there's no way anyone will be able to use any sway bar besides Hotchkis's as it's the only one that mounts inboard on the LCA. Also, an 18" wheel is practically required. I tried fitting a 17" Bullet Mustang wheel and it rubbed on the inner wheel. I'm not sure how the '73-76 cars are, but that's for the '66-72 cars. I hope that's of some help...
thanks chuck
ya, the 69' I'm doing has an early K, should be the original /6, but there was no motor so I still need to confirm that. choices being a full 73' up K and steering linkage. or keep the 69' K with /6 to SB conversion mounts and add 73' spindles. then I would use the hotchkis front bar so it wouldn't be so wide. probably going with firmfeel upper arms. cars going to see alot of street driving. guess i'll call FF and see if they know how the drdiff 13's fit rear mounted...
I love doing this, but it's a pain deciding which way to run when nothing's locked down yet![]()
MuuMuu101;1970730785...potentially cheaper said::burnout: oh, this is going to get auto-x'd and track day'ed to death so I'm planning on 13's.
it's like an old man without his Viagra, what goods a race car if you don't have it with you at all times![]()
thanks for the info 72bluNblu, I'm already leaning toward the 73+ K, just seeing if the earlier one is a viable option. will see what I can find at spring fling without a crazy price. all I need is the K, center link and knuckles. also resigned to 18's if that's all that will fit the brakes...
hey MuuMuu I am worried about cooking off the smaller brakesops:...
I'm near woodley park, where they have spring fling at. not too far if it's not rush hours![]()
LOL right now I have nothing...car still has the 9" drums until I can finish striping it. ya, the 13's are more for the planned track days than auto-x. I did spend a few yearsI wouldn't worry too much about the 11.75's. I seriously doubt you'd have any issues with them on an autoX course. Too slow, not enough consecutive laps (usually). I've been running the 11.75's on my Challenger for years now without any problems.
Road course or trackdays would be a little different. It would depend on the layout of the track and the number of laps you got to run. On a brake heavy course I'm sure you could get them to fade if you got to run for awhile.
Not saying the 13's aren't great, they are and I love 'em, but I don't think they're a mandatory upgrade to get started if you've already got 11.75's.
Digging up this old thread. Really appreciate the guys stepping outside the norm and fitting up bigger wheels for grip performance.
I just picked up a set of aftermarket wheels front 18x10, +40 offset, and rear 18x11 +52 offset. Came off a newer Boss 302 mustang. I'll be tossing these on my resto mod 69 GTS 383 car.
