Cool, thanks all for the informed replies.
I do understand that there are differences, and well, they are both front brake kits, so I was comparing them.
Just doing what most people do, trying to compare the bang for the buck based on material, hardware, performance and longevity.
Andy,
Well, I would say 1k is my limit on an out the door setup. Rotors, calipers, pads, caliper brackets, stainless mesh flex hoses. That's probably enough said but here are some supporting meanderings..
I do very much prefer any brand automotive production hardware or based on production hardware as much as possible, rather than custom parts like calipers, rotors, hubs. Wilwood looks like I will be buying willwood for ever when I need a new part.
I prefer to get the most stopping power and longevity for my buck.
Not interested in power brakes really at all. I would rather just push harder and run a smaller diameter master cylinder, unless the stroke wont fill the calipers before it bottoms out.
I am buying wheels, either 18 or 20. I do like 18 and 20 inch mustang wheel options and if they fit my back spacing needs I will use them being that the aftermarket mustang wheels are cheap. I am essentially going to buy wheels/offset/backspacing once the suspension is in place. Pro touring style car generally.
Car will be 1 - 2 " lower at the most. I still need to clear the tree limbs and rocks when I go Smokey and the Bandit style.
I am going to try hard to keep identical wheel / tire on 4 corners when I buy so I can rotate them and have large traction up front.
Full plan is: Duster. moderate - balanced 440 w/ ported al heads / 727 w tight converter/ 2.76 SG 8-3/4.
Stiffest bars all around. Poly everything. ff uca. boxed lcas. sf conns. boxed up k frame. braces where needed.
So, I need to stop a nose heavy street machine with reasonably large rubber on front and rear. Rear has 11x2.5" or 3" drums so, should be fine, uhm,I guess, or not.
I don't see any point in only going 120. I can do that with a Georgia overdrive, loaded with chickens. At least I could until the dang ICC started checkin' on down the line
I plan to get er up the point where it stops pulling in high gear and set the cruise control.
A year ago I bought a new 11.75 setup with exception of the used spindles. Reckon most of that will sit on a shelf.
I am going to look into your book.
Thanks.
