doogievlg
GOOD QUESTION!
For the new guys, here's the answer and then my answer to the thread starter.
Edelbrock sells there heads bare and fully set up with all the hardware. Which would be valves, seals, springs, retainers and locks.
There are 3 versions of a smallblock head.
The Magnum head.
The standard LA head
The 340 head which has a .060 relief for the early 340 piston engines because there pistons rise higher than the block.
This equals 6 heads to choose from.
To the thread starter and anybody else in this position.
It is possible to run in the 11's with iron heads! Or faster! BUT at this level, it really takes a deadacded drag car. Super light car. Lexan windows, fiberglass everything, etc.... Let's keep to the street version of this since the OP said he wanted to cruise the car.
For the price of ported iron, you should be as to least equal the air flow and exceed the Edelbrock head. This is the iron heads limit for the most part. (Extreme iron head porting costs more than a typical full porting and where not going there for a cruiser.)
The Edelbrocks offer a bit more and, well, also at the mandatory higher price.
Once you have the head, most people will tell you to have the machinist check it out and correct any possible issues. Add that onto the price tag of the heads.
The possible level of porting that a aluminum head offers in terms of air flow and performance is much greater than an iron head. But do you "NEED" it? Or just want it?
In the old MoPar Performance catolog, they offered "Tips" on what you will need to run a certain bracket E.T. I opened up my old book and looked in the section to see where it was they thought that running a ported head was a good idea in order to "Make that E.T." your looking to achieve. Well, it wasn't until the 12 second zone the suggest running there "Bowl Ported head."
In the 12.5 zone, for the 340/360, it is still as as cast head with good valves and a bracket valve job. Viton seals and the valve spring to match the cam. The thing the OP may not like is the suggested tire and rear ratio to run, which is a 4.10 gear and a 26 inch tire. (Slicks in this case sense these are "Track Tips")
I myself have run 4.10's for over a decade now and will travel on the Hwy. from L.I. - N.Y. To Carlie Pa. If your worried about burning a lot of fuel stay home or trailer the Queeen in.
If your worried about constant high RPM's, and question your engines health, I question your or your machinists build and talent.
And your faith in MoPars.
Ugh. I'm ordering the heads. This combo could run low 12s in a real lightweight car but I don't see a stock 360 with cam headers and intake and carb running 12s. Cal trace gears and slicks are next. I can afford to do all that in the summer.
