These components generate heat. plugged in OEM limiter usually had a piece of paper like material between its contact posts and the circuit board serving as a heat shield of sorts to block the generated heat from the printed circuit board. Solid state such as 7805 needs a heat sink and heat sink compound. I've watched the output voltage of those change. Some as low as 4.89 volts at cold start would slowly climb as high as 5.42 volts as it heats up (just powered up, no load).
Case to consider... I bought my 67 notch just outside of Seattle and drove it to Anderson SC, 2854 miles in 3&1/2 days. This was 2nd week in October so very little ambient temp change from morning to night, from one side of this country to the other. I noticed that after several hours of driving and totally random also, the gauge needle positions would just change, climb up a tad from where they had been. After a brief stop for fuel and coffee or a burger, the needles would go back to the earlier lower readings, except for fuel of course. And that gauge is the major contributor to work load. My point... the mechanical limiters have a few different failure indicators from slight needle changes to wild needle swings at switch on. Ambient temp change isn't the cause. Combination of generated internal heat and circuit load changes are the cause.
