ATK engines 408 sroker with Magnum block LA build
Paul_G
Active Member
Surprise, Arizona
Is anyone using one of these ATK engines? They're using Magnum blocks with an LA front cover set up for a mechanical fuel pump.
It sounds to me like a great combination. You get the hydraulic roller cam with the better flowing Magnum Edelbrock aluminum heads. And It Bolts right in place of an LA engine.
They are rating these at 465 horse, 535 torque.
Is there a downside to this engine?
On my phone. Do you have a link?
JP, Thanks putting up a link. Would this engine be better suited for racing? Or can it be used in a street cruiser, weekend bruiser, with AC, PB, PS, and run cool with the AC on in summer heat? ATK states it has a lopey idle. They also recommend a 2500+ converter stahl, which is not radical.
Hey Paul, these are a badass street engine! Its a hyd roller with a nice moderate cam, so it'll be very well mannered on the street. I have sold a few to street guys also. My bracket Buddy just chooses to bracket race it, and does quite well! still makes 12-16" vac.
i try to give a little fabo break on engines if/when you're ready. I only have good things to say about ATK and BP. Neither have let me down, and i recommend/sell both of them regularly.
I notice they have a complete engine from carb to oil pan. They say it's a street cruiser. $4844. 290 HP & 385 in torque. But they claim 10:1 compression, unless that's a misprint that seems kinda high.
