fratzog lover
Tie a piece of waxcord or white string on them. If your eyes are old like mine! The drag magnet has saved me once or twice out in the stone driveway.(but I serious dislike the microscopic pump and choke link clips).
I had to add some bend to my fuel line because of the electric choke, but the factory 1970 340 air cleaner fit fine.AVS2 I have needed about 3/8" spacer between the drop base aircleaner base and the carb. The fuel line inlet was hitting the aircleaner. No problem with the choke.
I unscrewed the fitting that the fuel line goes to from my original Carter avs, and used it on the avs2. Edelbrock recommends a banjo fitting that might work better, but I didn't need it. I did have to use the thick gasket, but I don't remember what issue caused me to need it. They also recommend a throttle linkage kit for mopars, but I didn't need it either. The only thing extra that I bought was the thick edelbrock gasket.Well I'm going to find out the hard way. Just put the order in for the 650 AVS2 and one of their thick thermal blocking gaskets. Going to be nice to finally have a carb that works right.
Mango,
Did you use AN fitting for the hard line at the carb or just a regular flare fitting? I don't think it should really make a difference? All the fitting they were suggesting online were AN but I don't think my flare tool is compatible with that. I'd like to have as little hose in the circuit as possible and I'm not paying big bucks for a pre-bent set.
Edelbrock has a drop base air cleaner that works great with the AVS carbs.Well I'm going to find out the hard way. Just put the order in for the 650 AVS2 and one of their thick thermal blocking gaskets. Going to be nice to finally have a carb that works right.
Mango,
I'd be interested in knowing this as well. I've been recommending this carb to anyone who will listen, but I've no idea about the kick-down linkage.Those of you using the AVS2 with an automatic transmission, can you post a good pic of the throttle and kick-down linkage? I figure I need to remove some of the stuff from the Holley and move it to the AVS2 but is it just the stud, or that bracket as well?
gzig5 - I believe the AVS2 kickdown linkage will carry over from the performer and AVS carburetor. I can show a couple pictures of that, if you think you'd care to see it.
7milesout
Looks like something is bolted onto the stock linkage. Is this it?
Edelbrock Throttle Lever Adapters for Performer Carburetors 1481
Not sure what pricing youre looking at, but a 750 Street Demon is about $350+/- depending on where you source it, they are not "a lot more money" than any Edelbrock from what I've seen. The Demon is just about the cheapest out there.There are a couple of guys in our car club that run the street demon and they run ok but a lot more money than the Edelbrocks
I have also tuned and run Carters and Edelbrocks they are fine carbs just a tad old-school but I HATE the bowl design, can't go around corners or hit the brakes too hard you might stall out!
That's funny I have never had that issue with a Edelbrock but I have had more issues with the holley that I had on my 68 Coronet RT. Never could get it to run right one day perfect next day run like crap. Installed the 800 thunder series all issues went away. There are a couple of guys in our car club that run the street demon and they run ok but a lot more money than the Edelbrocks
The AFR gauge paints the picture perfectly clear. It's a lean spot.
