I purchased this setup over two years ago, unassembled so I have a couple questions: I believe I have the Green bearing setup as both sides look identical (no adjuster) and there's an "O" ring seal on the outer bearing keeper. I have assembled third member, axles, brake assemblies and housing. I'm assuming assembly is pretty straightforward, axles simply slide in w/no adjustments needed (so simple even a caveman can do it ) ? Thanks for any input - also have 3/4 spring relocation kit, perches moved - what's the issue with the front spring hangers (I recall an issue with the bolts and haven't gotten that far yet ) ? Hope to have all installed today.
