Hello. On my 8 & 3/4 rear axle, which gasket goes where? Theres a couple 5 bolt flange gaskets, with a flat on the top. A foam/paper and a steel gasket. Does the foam one go behind the backing plate, and the steel on the front where the bearings are? I converted to the green style bearings with the C-clip retainers....
How I had it before, I had the steel gasket behind the backing plate and the paper gasket behind the axle...Now I have it mostly apart, and I think I have it backwards...LOL. If the steel unit goes in front, is it okay if I leave the existing steel gasket behind the backing plate?
Sorry for such a dummy question..
