What axle flange gaskets are you running on your 8.75?
In DrDiffs brake kit it says to run fiber gaskets with green bearings and not stock metal ones. I have 2 fiber ones that were in my pile of gaskets, the Dana 60 axles I pulled out had like a rubber gasket that seemed 100x better than the fiber gaskets?
So what gaskets are you running on your 8.75 axle flanges? Picture of the rusty axle housing is mine that had cheap gaskets on it years ago when I put the rear end back together.
