CDA1967NBK
Member
All set, Thanks John!!make sure you installed the new inner seals far enough into the housing -- if not the axle bearing collar will bottom onto the face of the seal ---- face of the seal should be about 1-11/16 inch in from the face of the housing flange -- there is a lip in the housing end that the seal will bottom out on -- if installed properly.
