[WANTED] Back up light actuator pin!
65dartcharger
Dart Charger 273 Historian
Tavelsjo, Sweden
I'm searching for the actuator pin for bac-up light for 1965 Dart and Valiant with automatic on the column.
This is how it look.
Thanks FABO
Well, I looked and looked but must have thrown the one away from my wagon's steering column sorry to report
I hope you find the correct part. A long time ago a owner/member here figured out how to replace that with more common hardware. I don't recall exactly what hardware was used. Button head bolt ( like "closet bolt", holds a toilet to the flange ) installed from inside out maybe? Or maybe he altered the tube to accept a 'U' nut and put a stud in it. Whatever went there had to be shallow, clearing the shaft inside. I do recall he took the column completely apart to do whatever he did. I assume his is still working fine today. Repairs don't have to be as simple to assemble and/or service as what the OEM engineers came up with. Only needs to function the same. Good luck
I thought I had one laying around but haven’t had a chance to put my hand on it, sorry for the delay. I’ll get back to you next week.
Jake
