74desertduster
So I have been dealing with a poorly running slant for a week or so now.
I stopped for gas one day and poof, it started running really badly. I'm sure it was slowly getting worse and reached a tipping point that particular day.
Prior to that I have recently changed the plugs, cap, rotor, all the normal tune up items including coil. Ran great for a few days and then, bam...poop.
It has acted like a carb problem to me. I have adjusted the idle mixture and curb idle as best I can. Idle mixture screw has very little impact until almost seated. Curb idle is not so high as to be taking the idle mixture out of the process.
Timing has been by ear as I have no timing marks and have yet to get a vacuum gauge.
So today I pulled the plugs out, thinking they were probably fouled with something based on the very poor running and lack of power. Had Champions in there and got NGK ZFR5N to put in.
The plugs, all 6, are extremely carbon fouled. Like I have almost never seen. Put in the NGK's and runs great again.
Would this most likely be an overly rich problem with the Holley 1920?
