1967formulaS
I've got a big weird coolant leak in the 440 and it looks like it's coming from behind the exhaust manifold gaskets on both sides. I'm using fenderwell headers and copper gaskets.
I've also used my original 383 engines closed chamber heads on the 440 and arp header bolts.
Is it possible that coolant is coming from the bolt threads?? Do They enter water jackets in the heads.
I've got 2 sets of normal exhaust manifold gaskets ready to use.
Coolant Temp is at 80 degrees Celsius, timing at 10 degrees initial, oil pressure is good.
I'm freakin out!
I'm gonna start pulling the headers out and I'll see if I can borrow a friends pressure tester to pinpoint the leaks.
Anyone else experienced this Issue.??
I'm freakin out!
