Cudaroy
Hi all,i just found crack in cylinder #2 on my 1990 318 block after a very trying week. it is getting cold up here in NH so last weekend flushed out the old coolant, hooked up the heater hoses, put new prestone in it and fired her up. Noticed after about 5 minutes the right side exhaust smelling kinda sweet and white smoke coming out. I thought maybe some sealer might work.NO! Then on Friday I replaced the head gasket and no change. I figured maybe the head was cracked so I went to a friend and he loaned me a set of 596 heads to try. I removed the heads and used a mirror to look at the#2 cylinder and lo and behold found what looks like a crack around the 12 o'clock position. Motor only has 6000 mile since the .030 over b
ore but the walls look very thin.The motor is a 1990 Truck block so beware! I didn't have the work done but bought the engine as a long block, tore it down, replaced the crank as #4 and#8 journals had spun and ran great until I flushed out the coolant.
Guess I'm in the market for another engine...........
