If you have the early 2 piece magnum balancer, then yes, the LA pulleys just bolt on- depending on the year of the pulleys, one hole may need to be elongated.
If you have the later 1 piece balancer/pulley, you'll need to swap to the early Magnum balancer.
Mopar Small Block Harmonic Balancer | 273 | 318 | 340 | 360 | 408 |Thanks! The one I have is the one piece. I'll source the correct one. Thanks for the info.
Yes, that's what I meant- the early ones had separate balancers and pullies, later ones were a single piece.I may have misunderstood what you were saying. When you say 2 piece balancer is this what you mean?
This is the one I currently have.
Your LA pullies should bolt on, depending on their original year they may need 1 hole elongated, no biggie- just takes a minute or two with a rat-tail file.
