stupidasso
CA ANRCHY
Hi all,
I have my engine in the car, and want to put in my roller rockers. I just got some clevite ball and cup push rods for the job. Nowhere can I find the specs to put adjustable roller rockers on a hydrolic cam engine. My setup is a 360 with the stock 340HP grind purple shaft and hydrolic lifters. the roller rockers are proforms that have an adjuster screw. My question is how do I dial these in correctly. Is there a sequence where each cylinder needs to be at tdc and then a clearence check for the roller on the valve stem? Thanks in advance for any help.
- Stu
:headbang:
- Stu
:headbang:
