Barracuda door panels
You will need to remove the retaining clips from the door and window
handles. Then remove the screws from the arm rest. Next the panel
should pop off by using your fingers.
I hope this helps.
Bill
Mine is a 67, and there is an allen head screw in the center of the window crank, then the door pull has a screw behind it, stick the screwdriver in with the phillips head facing the rear of the car. There are 2 screws on the bottom of the door pull/arm rest. Then use a flat head or a gasket scraper to pop the clips out all along the edge, these should stay in the door panel so be careful and make sure they come out with the panel and do not stay in the door.
there is a special forked tool that will slide in between the panel and the door and pry those clips out correctly. The backer board gets brittle with age so nothings a sure bet.
The panel will pull down and out of that stainless trim piece across the top. Be careful when pushing it back up in there so it doesn't roll the vynil down away from the board. Hope this helps
best way is to get a door panel tool,slip it behind each clip and they pop out,then you dont ruin the door panel,take your time doing it
