Barracuda Rear Seat
bob7four
New Jersey
I cannot get the back seat on my 69 Cuda convertible to budge. Any trick or suggestions on how to get it out?
I am guessing you are talking about the bottom part. I know mine was also hard to get out. It hooks in like a regular back seat bottom. I had to bounce on it while hooking my fingers under it and push back with my legs and lift. Took a few tries but it did come out. Then you will be able to remove the two nuts holding the top portion and lift it up.
Push down, rearward, then up....
Lather, rinse, repeat until you get it out...
Yes what he said. May try at front end of one side then the other that's how I have to do mine then pull up and towards you.
The seat backs sag downward over time. If you can force it upward a little the seat bottom will move reward easier.
