basic Holley 4 barrel cleaning?
diymirage
HP@idle > hondaHP@redline
michigan
ok, a proform 750, but pretty much a holley
about a month ago i fouled a fuel filter and in order to make it back home i ran the car without a filter
of course, all the crap that clogged the filter now got into my carb
it wil run fine one moment, then idle really high...i caught her doing that once and i pulled the air cleaner lid just in time to see fuel dribbling down the carb and when i pulled the needle, sure enough it had a bunch of crud in the seat
at times it will stall out when your cruising at idle (i havent figured that one out yet, but i presume it is crud in the idle circuits?) luckily a little tap of the throttle will wake her right back up
at any rate, ive rebuild plenty of 2 stroke carbs but this is my first 4 barrel
my main concern is breaking seals that may need replacing and missing hidden circuits...so what advice can you professionals give me?
Take the bowls & metering blocks off and squirt carb cleaner with the extension through every hole in the metering blocks & carb body. Can't hurt to remove the metering adj. screws as well. Spraying into the needle & seats to flush them out might be enough without having to remove them. (Watch your eyes.) Flush the line between the filter & carb too.
Just buy a kit with all the gaskets, don't buy parts store ones, factory holley ones are not much more $$.
Also blow the carb passages out with air, or you are wasting your time.
Holley has an excellent video tutorials on their web site.
thanks, if i can ever figure out what exact carb i have, i should be able to figure out what kit i need
so, the chances of pulling the bowls and blocks of without breaking the gaskets are pretty slim?
This^^^^^
Unfortunately, Myron is right. Every single carburetor dip that used to work is now fodder for play school kids to play around with thanks to the EPA. In fact, I have gotten to the point to where I replace carburetors for my small engine customers. Piss on trying to make them right after ethanol. It's not worth the work.
A cheap cleaning fix is a old crock pot and a mixture of 50/50 simple green and water, do not leave it for more than 24 hrs, it will strip the finish clear off a carb.
On the front of the air horn of most Holley carbs is a "List" number. That's the number you need for a kit.
Have you tried some Barryman's 12 carb cleaner to blow out the passages??? Available at Auto Zone...
Only use it in the garage or outside, the fumes are strong...
Yes sir, i took out the air idle screws and blew the through with it, hit the jets with it, and removed the pumpshot nozzles and cleaned it...it just seems there is more crud then I can get at without disassembling it
Disassemble it and blow out all of the passages and bleeds....
If you don't take it apart, you will just be blowing the chips/dirt into another section.... :BangHead:
Got her all cleaned up and running again
Well, I had her running, about 5 miles into the shakedown run she died on me
I got other stuff to do now, so I'll check into it later
(Showing 0 psi on the fuel pressure gauge and nothing in the sight glasses)
This is what the bowls looked like
You need to clean or replace the fuel tank. That's nasty.
Best thing I ever did for my 66. Replaced the tank, sender and line. Rebuilt my carb and haven't touched it for 10 years.
it looks like what is holding me back now is the little section of rubber fuel line that connects the sending unit to the hardline running up to the front of the car
i had 0 fuel pressure, car was barely idling
on a hunch i crawled under there and squeezed that little line into round again and the idle got better
i looked under the hood, and 8 pounds of pressure (i had messed with the regulator some, its adjusted back down to 6 now)
so, any suggestions on how to keep that line from collapsing?
(and i most likely will replace the tank over the winter, i allready have a new 3/8th sending unit and fuel line ready)
