22dog22
Hi All, I have a battery problem, I have a 4 year old Exide lead acid battery, over the past few winters I have had a Battery Tender brand hooked to car over the winter, I have used this same unit for the past 3-4 years never had a problem, had charger on battery some how the Battery Tender unit seemed to over charge battery had acid leak from vent caps, all over , had to replace the started relay was covered with acid, also took out my voltage reg. sent the unit back to Battery Tender thinking it was still under warranty but as normal was not, so bought a new unit which I had hooked up till the early spring of this year, but still was getting acid coming out of the vent caps and covering the battery tray with acid damaged, I have since taken the Battery Tender unit off the car , and today with just the car battery cables hooked up had the same acid damage to the battery tray , now I have made sure all the time that the battery cells where not over filled with water to cause this . Any ideas thoughts ??
