cuda guy
- Joined
- Oct 15, 2009
- Messages
- 496
- Reaction score
- 33
Hi all
Im Stumped Again
My battery has been draining when I turn the battery switch off. It is a Moroso switch the off side is wired to the frame as ground and the battery ground is to the on position. I have never wired this type of switch to ground only POS. Yesterday I was checking all the connections to the rear of the car when I put down the tester to check with the multimeter it touched the roll cage and lite up, the switch was turned off at the time. I started testing everything in the truck all the bolts were lighting up. I up hooked the switch and ran a direct ground and everything was ok normal.
I even ran a different power wire from the battery to front and still the same
What has me confused is that how is the power bypassing the ground and goin to my frame in the off position and than with a direct ground no issues,
I tried 2 different batteries all the same results,
Is the switch bad or is something else wrong.
Its a 68 Cuda has a 440 mildly modified ex race car
I rewired the car with a EZ wiring kit not so easy
It has an autometre dash insert
It has a proper engine ground
All the power wires seem ok and all the electrical seems to be working as it should
Im Stumped Again
